Add “Sampled” Salinity Input
Do you know what “Sampled Salinity” means? With HYDROS, you can now test Salinity more safely and accurately. By placing the Conductivity probe in the HYDROS iV, the Conductivity probe is located in a fully isolated vessel, ensuring stray voltage from equipment like pumps or heaters won’t compromise the readings.
TIP: When configuring your
iV Tester Output, this input is automatically generated and added to your status screen. If you need to recreate it manually, follow the instructions below.
Before Creating the Sampled Salinity Input…
- Ensure you have a fully configured iV Output.
- Select a Salinity Input at the bottom of the iV Output configuration page
Now, we can manually create the input.
Step 1: Create the Sampled Salinity Input
- From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
- Select “Add/Edit Input”
- Tap on the + symbol in the bottom-right corner
- Enter the name you wish to assign to your input and tap “Create.”
Step 2: Configure the Sampled Salinity Input
- Type: iV Test
- iV Tester: Select your iV Output
- Test: Sampled Salinity
- Safe Range: With this feature, choose the minimum and maximum values. You will receive a notification if a reading falls outside of this range.
- Graph Value Limits: You can determine the range of values shown on the Graphs view by setting both a maximum and minimum value.
- Stale Sample Notification: The Control can notify you if the last reading is too old. If the HYDROS has not received a new reading within the time selected, it will notify you if you have enabled the notifications below.
WARNING: If the reading becomes stale/old, any output or dosing using this input will show a red warning and revert to the “Fallback” state.
TIP: We recommend you set this to 1.5 times your testing frequency. i.e., If your iV Testing Output is on a 4-hour testing schedule, we recommend you set this value to 06:00:00
- Notification Level: This option allows you to specify what notification level you would like to receive. You will receive notifications when
- The sensor becomes WET
- Control has lost connection to the sensor
Step 3: Upload the changes
- Once you upload the changes, the status screen automatically displays a new “Sampled Salinity” input.
Calibrate/Offset Reading
If you notice an inaccurate Sampled Salinity reading, you can go to the Conductivity/Salinity Probe Input setup page and recalibrate or apply an offset there.
- From the STATUS screen, tap on the Input you wish to modify.
- From the Input setup page, tap on the “Pencil” icon on the top left.
- If you wish to change the default icon, please tap on “Change Icon.”
