Adding a Rope Leak Detector Sensor is very simple.
Step 1: Physically Connect the Sensor
Connect the sensor to your Control unit’s Sense Port (GREEN).
Safely secure the sensor in your aquarium, ensuring that the sensor cannot become dislodged.
From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
Select “Add New Input”
Tap on the + symbol in the bottom-right corner
Enter the name you wish to assign to your input and tap “Create.”
Type: Select Sense Port
Sense Mode: Select Rope Leak Detector
Sense Port: Select the port number where you physically connected the input sensor
Trigger Threshold (Sensitivity): With this feature, you can adjust the rope’s sensitivity. Increasing the sensitivity (lowering the number) means that the rope requires less water contact to trigger a leak status.
WARNING: If the sensitivity is set too high, it could result in a false alarm being triggered by accumulated moisture. Testing different levels may be necessary based on the humidity levels surrounding the rope.
Notification Level: This option lets you specify the notification level you want to receive.
Alert When Dry: With this feature, you can reverse the notification setting on the leak detector so that you receive an alert when the rope changes from being wet to dry.
Step 4: Upload Changes
Once you have configured your INPUT, tap on the yellow bar at the bottom of the screen to upload your changes to the cloud and the individual HYDROS devices.
Type in the new name you wish
