The HYDROS Dual TDS Sensor is an easy way to monitor and track the water quality used in your aquarium.
The HYDROS Dual Inline TDS Sensor will monitor water quality from a Reverse Osmosis (RO/DI) System. Each Sensor plugs directly into any available Sense Port on the Control XS, Control X2, Control X4, and future HYDROS devices.
Track TDS readings on user-friendly HYDROS App
Includes two high-quality titanium sensors
Small and compact design
Easy magnet mount display
Powered, monitored, and control by plugging into a Sense Port on a HYDROS Control
TDS Sensor
Sensor Cable
Display Cable
.25″ Push Connect Fittings
Range – 0-999ppm
Resolution – 1ppm
Accuracy – +/- 2%
Sensor Cable Length – 24″/61cm
Display Cable Length – 13’/4m
Each HYDROS Temperature Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port and DOES NOT require any additional power source to operate.
Install TDS sensor in appropriate and desired location.
Connect the TDS sensor to any available green Sense Port.
