The HYDROS 4 Outlet WiFi Power Strip is a smart power bar designed to connect devices like pumps, power-heads, lights, and more to the HYDROS Control system. The HYDROS power strip and HYDROS app work hand-in-hand to create rules and schedules to turn different pieces of aquarium gear on or off. The HYDROS 4 Outlet WiFi AC Power Strip is included with the Control Starter Kits and is also available for purchase for system expansion.
Uses a 2.4 GHz WiFi frequency
Create rules & schedules to turn equipment on or off
Receive notifications if connected gear fails
Bracket included for easy mounting
Control multiple power strips on one app interface
Requires a HYDROS Control and HYDROS App to operate; Controls sold separately.
Power: AC 120V | 3×2.08mm2 | 14AWG
Outlets: 4 X AC Outlets | 4 X USB Ports
Outlet Spacing: 0.375in -9.53mm
USB Spacing: 0.250in-6.35mm
Total Power Rating: 10A/1250W
Total USB Power: 5V/1A*4 (Max 2.4A)
WiFi Frequency: 2.4 GHz
Dimensions: 7.8 x 4 x 1.1in/198 x 96.5 x 27.94mm
Cord Length: 56in/142cm
Weight: 483g
These outlets are ideal for controlling the power to aquarium devices such pumps, power-heads, lights, heaters, algae scrubbers, UV sterilizers, protein skimmers, and more.
Set-up Example – Connect a protein skimmer, return pump and two flow pumps to the power strip. Then use the HYDROS App to create a rule that makes all connected gear turn off during routine maintenance such as a water change. You can then set up a rule to have the equipment automatically turn back when maintenance is complete.
These ports are ideal for connecting and controlling low power aquarium devices such as fans, WiFi Fish Feeder, LED cabinet lights, and tablet.
Set-up Example – Add two cooling fans to your aquarium. Simply connect them to the USB ports and then using the HYDROS App, create a rule that makes the fans turn on if the aquarium water gets too warm*. Then have it automatically turn off when the water temperature drops back down to its ideal range.
*Temperature sensor required for this process, sold separately.
