The HYDROS WiFi Fish Feeder is suitable for a variety of fish foods and is the perfect accessory for a busy or traveling aquarist. Using the free HYDROS app for Android and iOS/Apple mobile devices, you can now feed your fish wirelessly over a 2.4 GHz WiFi frequency from anywhere in the world. A HYDROS Control is required to operate. This fish feeder is compatible with all HYDROS Control devices and the WaveEngine V2 (not compatible with WaveEngine LE & WaveEngine V1).
Easily schedule feedings through HYDROS App
Compatible with Control XS, X2, and X4 (or any other future HYDROS Control device)
Includes desiccant media to prevent moisture from getting to the food
Chamber (~165ml) is large enough to feed your fish while you’re away
Quick and easy set-up with 3 mounting options
Product Details:
Material – ABS
WiFi Frequency – 2.4GHz
Product Dimensions – 13.5x6x6.5cm
Cord Length – 9ft 10½in
Capacity – 165-175ml
Power Supply – USB Cable
USB Power – 5V
Install fish feeder in desired location on aquarium.
Add Wifi Device to app, then connect fish feeder to any available USB. Configure WiFi device and then add output.
Connect fish feeder to any available USB.
No complicated coding, debugging or frustrating workarounds – it takes only seconds to add the HYDROS WiFi Fish Feeder to your network.
