With the HYDROS app and Smart Plug, control aquarium equipment with customizable on/off schedules, including pumps, powerheads, lights, heaters, scrubbers, sterilizers, and skimmers.
The HYDROS WiFi Smart Plug allows you to wirelessly control a single outlet through the HYDROS app on an Android or iOS device. It can also measure the current and wattage of the device it powers and has an LED status indicator. The Smart Plug operates on a 2.4 GHz WiFi frequency and has a range of 98 feet, making it easy to place around your home without difficulty connecting to your modem or router.
Uses a 2.4 GHz WiFi frequency
Create rules & schedules to turn equipment on or off
Receive notifications if connected gear fails
Control multiple smart plugs on one app interface
Requires a HYDROS Control and HYDROS App to operate; Controls sold separately.
Power: AC 120V
Outlets: One AC Outlets
Total Power Rating: 10A
Total USB Power: 2A
WiFi Frequency: 2.4 GHz
Max Range: 98ft
The Smart Plug allows you to control multiple devices from a single app. For example, you can use one to power your display tank heater, another for your return pump, and a third for your office lamp as an alert if a device is not operating normally. There are so many ways to use the HYDROS WiFi Smart Plug.
If an outlet loses WiFi connection or fails, you’ll receive alerts on your mobile device. This safety feature can prevent tank catastrophes.
For example, if the outlet powering your return pump failed, you would receive a notification to let you know something is awry so that you can take corrective action. As a temporary fix, you can turn on all your flow pumps and increase their speed remotely via the HYDROS app to keep the water moving and the temperature stable until you can arrive home to investigate.
