HYDROS Rope Leak Sensor Kit
The HYDROS Rope Leak Sensor is a flexible rope-like material that detects the presence of moisture anywhere along the rope. It can sense when freshwater or saltwater is underneath it and use that information to protect your aquarium, home, or office from serious damage. The rope leak sensor plugs directly into any available Sense Port on the Control XS, Control X2, Control X3, Control X4, Control X10, or any future HYDROS Control device.
Protect your investment both inside AND outside of your aquarium. Avoid sudden disaster by lining any large body of water with the flexible HYDROS Leak Rope Sensor.
Protects your aquarium and your home from a catastrophe
Allows you to take immediate actions such as shut off pumps and/or shut down protein skimmer*
Receive a mobile alert when leak is detected
Daisy chain up to 50 rope leak sensors together (Extension Rope Leak Sensor sold separately)
  • Control X3-S
  • Minnow
Rope Length – 9ft (2.7m)
Diameter – 0.18in (4.7mm)
Each HYDROS Leak Rope Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port and DOES NOT require any additional power source to operate.
Install rope leak sensor in appropriate and desired location.
Connect sensor to any available green Sense Port.
The HYDROS Rope Leak Sensor is the first of its kind in the aquarium industry. The moment water comes into contact with it, you will be immediately notified.
Wrap the rope leak sensor around your aquarium, sump, stand, or wherever else you like. This type of sensor makes a lot more sense when you want leak detection security in a wider area. You can configure the HYDROS app to perform whatever action(s) you want to happen when a leak is detected: flash a specific light color on your HYDROS controller, turn off a pump, shut down your protein skimmer, send you a mobile alert so you can come home (or ask a friend to check on the tank). It’s easy to do and you’re in control.
