The HYDROS 2mL/min Dosing Pump automates adding supplements, trace elements, and two-part solutions to aquariums.
The HYDROS 2mL/min Dosing Pump is an affordable and easy-to-use pump that can be used to automate the addition of liquid supplements, trace elements, and two-part solutions to an aquarium. By connecting the pump to a timer or aquarium controller, you can completely automate the dosing process. Each pump is designed to dose a single solution. Please note that a 120V Timer or Controller is required for automatic on/off operation, and must be purchased separately.
Quiet Operation
Will not back siphon
Four (4) rotors
>2,000 hours pump life
Easy to use with digital timer
*Requires a 120V Timer or Controller for automatic on/off operation, sold separately.
Fluid Volume: >1.4mL/min
Accuracy: +/-2%
Average Output: 2ml/min
Power: AC 110V/10w
Tubing: Uses 3mm ID and 5mm OD
