A Sense Port is a universal input port designed to connect and accept data from many different sensors. Sense Ports makes it easy to add sensors to your HYDROS network.
Install sensor in appropriate and desired location.
Install Sense Port accessory to any available green Sense Port.
The Slim Temperature Sensor has a long 79-inch cord with a GX12 aviation-style connector that plugs into any Sense Port on the Control 2, Control 4, and future HYDROS devices.
The easiest way to install a temp sensor to an aquarium or sump. A magnetic coupling securely holds the sensor in place on surfaces up to 1/2-inch thick.
The HYDROS Leak Detectors are easy and affordable ways to sense when freshwater or saltwater contact the sensor and use that information to protect your aquarium, home, or office from total disaster.
The HYDROS Leak Detection Sensor is a solid surface leak detector that can sense when freshwater or saltwater is underneath it .
The HYDROS Rope Leak Detection Sensor is a flexible line that detects the presence of moisture anywhere along the rope.
The HYDROS Water Level Sensors are small and contain no moving parts that can fail.
The HYDROS Water Level Sensor is an optical sensor you can use for a variety of aquarium applications, such as sensing when your tank needs to be topped off or to detect when a dosing container needs a refill.
The HYDROS Skimmer Sensor serves a very specific and important role: it prevents your protein skimmer from overflowing onto the floor or back into your sump.
The sensor plugs into any Sense Port on a HYDROS device (like the Control 2 or Control 4) and does not require any additional power source.
