The HYDROS iV ensures accuracy in readings by eliminating any interference from other electronic equipment in the aquarium system.
The HYDROS iV is a Drive Port accessory that removes electrical noise from water samples, resulting in more precise test results. Equipped with a magnetic stirrer, it comes with a beaker and allows for isolated readings of pH, salinity, and alkalinity tests. It is compatible with Control X4 and Control X10.
Isolates pH and conductivity readings from the aquarium for interference-free measurement
Thoroughly mixes test sample
Stable tabletop base and surface mountable
iV base unit
Two probe holders
Four acrylic rods for attaching tubing
Mixing pill
150ml glass beaker
Pre-mixed kH testing reagent
Dimensions (LxWxH): 4.5 x 3.5 x 7.5″ (not including probes and tubing)
Available Holders: Two probes and four acrylic tubing
Beaker Size: 150ml
Drive Cable Length – 6ft
Dosing pumps(s), controller, pH, and conductivity probes are not included and are sold separately
The HYDROS iV can provide an isolate of the ORP and pH simultaneously.
The largest issue with salinity probe readouts in a home aquarium is stray voltage from running equipment. With the use of several dosing pumps along with a salinity probe and controller, a user can obtain accurate aquarium readouts.
For accurate measurement of your aquarium’s water kH, you need both the HYDROS Control X10 and iV. By utilizing three of the four precision dosing pumps, you can effortlessly automate the alkalinity testing process.
