The HYDROS WaveEngine LE can control, monitor, and supply power to various aquarium pumps.
Combine pumps of all different brands together, specify each pump’s minimum and maximum speed and watch them work seamlessly together in a single integrated flow management system.
Easily tap into the native control platform to access all the preset flow patterns
Create operational modes such as feed, water change, or night mode
Monitor power consumption (volts, amps & watts)
Monitor pump’s RPM to ensure maximum performance
Full cloud connectivity so you can control your pumps from anywhere in the world
Real-time notifications of system status & pump performance
Define custom flow patterns of any duration up to 24 hours with 1/1000 second accuracy
Power up to 2 pumps with the Direct Drive ports using a single 100/240V 4 amp input power supply.
Connects to the following Pumps:
Models: XF-130 / 230, XF-150 / 250, XF-330 / 350, XF-280 | |
Models: RODC-2500, 3500 and 5500, VarioS-2 and 4, Octo Pulse 2 and 4 | |
Models: 1K, 3K, 2K, 4K |
Not only can you control your pumps from anywhere, you can monitor them, too! The WaveEngine tracks a lot of useful data you can use to ensure your pumps are running optimally.
You have the option of controlling your pumps locally via WiFi, which you do not need an Internet connection for, or remotely using the HYDROS Cloud. HYDROS Cloud allows you to communicate with the WaveEngine via the Internet. HYDROS Cloud is part of the Amazon Web Services and Internet of Things platform to ensure high security and reliability.
Local control gives you the option of direct access to your control settings in the event your Internet connection is unavailable. No matter your situation, the HYDROS WaveEngine LE will work to keep your tank inhabitants alive!
You can use a Maxspect Gyre at one end of your tank and a Reef Octopus OCTO Pulse at the other and both pumps can work together simultaneously or opposite of each other. The choice is all yours thanks to the WaveEngine LE pump controller.
Also, the WaveEngine LE can receive commands from other devices through its 0-10V input port including push-buttons, float switches, and much more.
The WaveEngine LE is designed to thrive in the wet and salty environment of an aquarium stand. It is sealed inside a watertight, dust-tight, IP65-rated industrial enclosure that can get wet without affecting performance. The connectors we use are rugged, color-coded and screw on securely. These type of connectors are used on aircraft worldwide and are proven to be tough and reliable.
HYDROS WaveEngines are assembled by dedicated aquarium hobbyists in-house at CoralVue headquarters in Slidell, Louisiana.
If you can’t find what you’re looking for in the frequently asked questions, where to buy, or pump compatibility, please contact us.
