The HYDROS Water Level Sensor is an easy and affordable way to monitor the water level in your aquarium so you can keep it within the safe zone for fish, coral, and inverts.
The HYDROS Water Level Sensor is a Sense Port accessory used to measure and monitor the water level in aquariums or other containers of water. It can detect when your tank requires topping off or when a dosing container needs a refill. The device plugs into any Sense Port on a HYDROS device and requires no additional power source.
Optically sense water levels
Can be used to sense high or level levels
Control water-level sensitive equipment like ATO, heaters, and dosing containers with ease
Receive a mobile alert when water level drifts outside the safe zone*
No moving parts, magnetic attachment
Sensor – .55” thick
Magnet Mount – 0.25″ thick
Diameter – 0.75”
Cord – 98”
Each HYDROS Water Level Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port and DOES NOT require any additional power source to operate.
Install water level sensor in the appropriate and desired location.
Connect water level sensor to any available green Sense Port.
The HYDROS Water Level Sensor is a “set it and forget it” water level monitor that requires no calibration or maintenance (except for perhaps the occasional cleaning). The sensor has a long cord with a GX12 aviation-style connector that plugs into any Sense Port on a HYDROS controller. You can use multiple water level sensors on your system for safety and redundancy. For example, you can place one in your display aquarium and another in your sump. This can be helpful if your sump is in your basement while the display tank is on another floor of the house. The water level sensor is completely submersible so you can easily place it somewhere discreet, like in the back of an all-in-one aquarium, in the overflow, or tucked away in one of the chambers of your sump.
There are various ways to utilize the HYDROS Water Level Sensor effectively. One of the possible uses is to set them up as high and low-level sensors, which will allow automatic top-off systems to function. Another practical application is to place these sensors in dosing containers, which will ensure an accurate and precise dosage of chemicals. Moreover, these sensors can prevent equipment from running dry by cutting power to an outlet when the sensor is triggered. The sensors are not only easy to install but also convenient to move and maintain due to their user-friendly design.
