HYDROS iV PRO Isolated Testing Vessel
To obtain precise pH and conductivity readings, utilize the HYDROS iV Pro. This HYDROS Drive Port accessory is designed to isolate the test sample, preventing electrical interference from other aquarium equipment, and ensuring the collection of reliable data. The HYDROS iV PRO is equipped with a new sleek design, improved materials, and includes a door and glass pH probe. This guarantees more reliable data by eliminating any potential issues. Made in the USA utilizing additive manufacturing techniques.
The HYDROS iV PRO ensures accuracy in readings by eliminating any interference from other electronic equipment in the aquarium system.
Isolates pH and Conductivity Readings from the Aquarium for Interference-free Measurement*
Automatic Alkalinity Testing*
Mixes Test Sample
Stable tabletop base and surface mountable
Included in Package:
iV base unit with removable door
Two probe holders
Four acrylic rods for attaching tubing
Intake screen and mounting hardware
Mixing pill
150ml glass beaker
Glass pH Probe
Calibration Fluids
*Dosing pump(s), controller, and conductivity probe are not included and are sold separately.
Dimensions (LxWxH): 4×3.5×7″ (not including probes and tubing)
Available Holders: Two probes and four acrylic tubing
Beaker Size: 150ml
Drive Cable Length – 6ft
Dosing pumps(s), controller, pH, and conductivity probes are not included and are sold separately
Common Configurations
The HYDROS iV PRO is a versatile accessory that can be utilized for various applications.
Isolated pH and ORP readouts
The HYDROS iV can provide an isolate of the ORP and pH simultaneously.
Isolated Salinity Readout
The largest issue with salinity probe readouts in a home aquarium is stray voltage from running equipment. With the use of several dosing pumps along with a salinity probe and controller, a user can obtain accurate aquarium readouts.
Testing Alkalinity kH
For accurate measurement of your aquarium’s water kH, you need both the HYDROS Control X10 and iV. By utilizing three of the four precision dosing pumps, you can effortlessly automate the alkalinity testing process.
