HYDROS Flow Sensor
The HYDROS Flow Sensor is a Sense Port accessory that can measure water flow from aquarium equipment, such as pumps, to ensure it is running correctly. It comes in four sizes and plugs into any Sense Port on a HYDROS device without requiring additional power.
Using the HYDROS Flow Sensors can give you peace of mind that your vital aquarium equipment is operating correctly.
A method of ensuring reactor feed lines and return pumps are working correctly
If issue is detected, the App allows you to take immediate action, such as turn off pumps*
Receive mobile alerts
Six (6) Month Warranty
  • Control X3-S
  • Minnow
GX12 Aviation-style Connector
Each HYDROS Flow Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device.
Install flow sensor in the appropriate and desired location.
Connect sensor to any available green Sense Port.
Available in Four Sizes:
HYDROS 3/4-inch Flow Sensor
Flow Range: 40-800gph
Wire Length: 8ft
Includes schedule 80 PVC Unions
HYDROS 1-inch Flow Sensor
Flow Range: 50-1500gph
Wire Length: 8ft
HYDROS 1 1/2-inch Flow Sensor
Flow Range: 100-2500gph
Wire Length: 8ft
HYDROS 2-inch Flow Sensor
Flow Range: 200-4050gph
Wire Length: 8ft
HYDROS Flow Sensor
Monitor water flow with the HYDROS Flow Sensor. Simply plug it into a Sense Port on a HYDROS Control device and configure the app to take action if the flow falls outside of desired range. Basic plumbing knowledge, PVC adhesive, and pipe thread tape are needed. No additional power source is required. Use the sensor for reactor feed lines and return pumps, and have peace of mind that your aquarium equipment is working correctly. You can create rules based on the data collected in the HYDROS app, such as turning off equipment if the flow rate is above or below a certain threshold.
The HYDROS Flow Sensor is an official accessory for the HYDROS platform manufactured by AutoAqua in Taiwan. AutoAqua is a well-known and trusted maker of aquarium automation systems. CoralVue has extensively tested the sensor to ensure seamless compatibility with the HYDROS platform. The sensor connects to any HYDROS Sense Port using an aviation-style plug for safe operation and doesn’t require an additional power source. You can get remote alerts should disaster strike and take corrective action with HYDROS!
