The HYDROS Leak Detection Sensor is a solid surface leak detector that can sense when water is underneath it and will send notifications and take actions that will protect your aquarium, home, or office from total disaster. The device plugs into any Sense Port on a HYDROS device and does not require additional power.
Protects your aquarium and your home from a catastrophe
Allows you to take immediate actions such as shut off pumps and/or shut down protein skimmer*
Receive a mobile alert when leak is detected
Cord – 5ft
Sensor Dimensions – 2.5in x 2.5in
Each HYDROS Leak Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port and DOES NOT require any additional power source to operate.
Install leak sensor in the appropriate and desired location.
Connect sensor to any available green Sense Port.
The HYDROS Leak Detection Sensor is a reliable device that detects surface leaks in freshwater or saltwater, protecting your aquarium, home or office against any potential disaster.
The process is easy: plug the sensor into any Sense Port on a HYDROS Control device and configure the HYDROS app to perform any action you want when a leak is detected. No additional power source is required. Place the leak detector anywhere there is a potential for leaks.
Many aquarium leak detectors rust on the bottom. The HYDROS Leak Detection Sensor has a safety seal that makes it impregnable and long-lasting. Connect multiple sensors and use WiFi Power 4 power strips and Smart Plugs to power off the equipment in another room or turn on a specific light in case of a leak. HYDROS ensures you’re always informed in case of an emergency.
The HYDROS Leak Detection Sensor is an official accessory for the HYDROS platform manufactured by AutoAqua in Taiwan. AutoAqua is a well-known and trusted maker of aquarium automation systems. CoralVue has extensively tested the sensor to ensure seamless compatibility with the HYDROS platform. The sensor connects to any HYDROS Sense Port using an aviation-style plug for safe operation and doesn’t require an additional power source. You can get remote alerts should disaster strike and take corrective action with HYDROS!
