HYDROS Auto-Top-Off Kit
Why spend money on a separate and expensive auto top-off (ATO) system when HYDROS can do the job for you? The HYDROS Auto Top-Off Kit includes everything you need to turn your HYDROS Control device into an ATO System. It is perfect for maintaining water levels in small aquariums or all-in-one tanks with low water fluctuation.
The kit includes:
An auto-top-off (ATO) system automatically allows you to replenish evaporated water from your system. A water sensor is installed in your main tank, and when the water level drops too far, it will turn the pump on in the reservoir and distribute fresh water back into your aquarium.
Automatically replenish aquarium water
Ideal for low fluctuation applications
Includes HYDROS DC Micro Pump & Triple Water Level Sensor
Powered, monitored, and controlled by a HYDROS Control and HYDROS App
Included in Package:
HYDROS Triple Water Level Sensor (plugs into Sense Port)
HYDROS DC MICRO Pump (plugs into Drive Port)
Hang-on Tubing Mount
Tubing (8.5mm OD – 6.5mm ID)
Siphon Break
Compatible with any HYDROS device that has an available Sense port and Drive port.
  • And More…
DC Micro Pump Specs:
Size: 1.6″ L x 1.062″ W x 1.45″ H
Max Head: 8′
Power: 4.5W at DC12V
Style: DC Brushless
Life: 30,000 Hours (3 +years)
Tubing Size:
8.5mm OD, 6.5mm ID
HYDROS Triple Water Level Sensor Specs:
Diameter – 0.75″
Sensor:
0.25″ Thick
Magnet Mount:
0.25″ Thick
Max Mounting Thickness:
0.50″
Each HYDROS Accessory has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port or Drive Port and DOES NOT require any additional power source to operate.
HYDROS ATO Installation
ATO App Configuration
It’s as easy at 1, 2, 3
Follow our step-by-step instructions to configure the ATO system to your HYDROS App and Control.
