HYDROS Float Switch Sensor with Magnetic Mount
The HYDROS Float Switch Sensor with Magnetic Mount is a mechanical device that monitors water levels in aquariums or containers. It can be easily connected to a Sense Port on a HYDROS device and does not require an additional power source for operation.
The HYDROS Float Switch Sensor is an easy and affordable way to monitor the water level in your aquarium so you can keep it within the safe zone for fish, coral, and inverts.
Sense Port Accessory Highlights:
Mechanically sense water levels
Can be used to sense high or level levels
Control water-level sensitive equipment like ATO, heaters, and dosing containers with ease
Receive a mobile alert when water level drifts outside the safe zone*
Magnetic attachment
  • Control X3-S
  • Minnow
Float Switch – 3” long, 3/4″ in diameter
Magnet Mount – 1″ in diameter
Magnet Sides – 3/8″ (10mm) thick
Max Mounting Thickness – ~2cm
Diameter – 0.75”
Cord – 78”
Each HYDROS Water Level Sensor has a GX12 aviation-style connector that securely plugs into any HYDROS device with an available Sense Port and DOES NOT require any additional power source to operate.
Install float switch sensor in the appropriate and desired location.
Connect to any available green Sense Port.
The HYDROS Float Switch Sensor is a highly efficient water level sensor. When used with a HYDROS power strip, this exceptional device can trigger various actions, including Automatic Top Off and Alarms for Water Level. It boasts a magnetic mount that makes installation a breeze and can be used in freshwater and saltwater aquariums.
The sensor features a GX12 aviation-style connector that allows it to maintain its IP65 rating, ensuring that it remains highly durable and resistant to damage. Plugging the sensor into a Sense Port on the HYDROS Control provides the means to power, monitor, and control the device, making it incredibly versatile and easy to use.
