The Control X4 Probe Ports ensure your readings will be accurate and reliable.
A Probe Port is a universal input that provides the very best readouts from your probes.
The circuitry is based on an ultra-high-quality input chip specifically designed for these types of probes. Each input provides Digital Galvanic Isolation (DGI) from the rest of the system. Probes send small electrical signals to the port. The signals are converted into usable data like pH and ORP levels. Even the slightest electrical interference from pumps, motors, and other equipment can cause fluctuations in the measurements and provide inaccurate readings. DGI prevents signal interference by converting it to the digital domain.
Remove probe cap and securely install within your sump or calcium reactor.
Connect BNC Probe to either of the Control X4 Probe Ports.
Select the location of the probe and enter your desired settings.
