With local WiFi control, you can still access all of your settings even if your internet connection is unavailable. You also have the option to connect remotely using the HYDROS Cloud. This gives you the ability to access your HYDROS system safely and reliably from anywhere in the world.
A HYDROS automation system uses a distributed web to monitor and control equipment for your aquatic environment. We call it our HYDROS Safety Net. Unlike other automated systems, HYDROS Control can not only withstand possible communication issues, it can also handle other critical situations that could arise when a device is removed or shuts down!
Run as many, or as few,
devices as you need.
There is no need to buy everything upfront or “UPGRADE.” You can simply start from a single Control X2. As time and budget allow, you have the ability to construct a massive network of multiple HYDROS products. They will all seamlessly work together!
You can easily expand the HYDROS Safety Net to manage multiple Aquariums!
With HYDROS, you’re not limited to one aquarium either. You can easily expand the HYDROS distributed network to manage multiple aquariums too. Suppose you have a large aquarium in your home, and a reverse osmosis filter and barrels in your garage; you can use a HYDROS Control X4 for your tank and a Control X2 in your garage to manage your RO system as well as track the level of purified water in the barrels.
We use the best of the best – Amazon Web Services and Internet of Things (AWS IoT). Highly Secure and Highly Reliable!!
Like a safety net, the HYDROS System is built to keep your web working together for the collective. All HYDROS devices speak to each other and share the responsibility to accomplish a single goal – keep your tank running smoothly and be notified immediately if something’s not right. The HYDROS Control is built to function properly and keep your aquatic life alive and thriving!
