Add Water Change Schedule
The schedule is the “Action” part of the Automatic Water Change Output. Without a schedule, the AWC will never run automatically.
Step 1: Create a New Schedule
- From the main menu, tap on “SCHEDULES.”
- Tap the + symbol at the bottom right and enter your Presets name.
- Tap Create
Step 2: Configure the Schedule
- Type: Select “Water Change Regimen”
- Water Change Count: In this field, you specify the number of water changes evenly spaced out between the AWC Start and End Times defined below.
TIP: The count defines the STARTING time of the water change. If you set the count to 1 and the Start and End time range is 24 hours, the water change will start at midnight. It will NOT slowly run for 24 hours.
- AWC Output: You select the previously created AWC Output in this field.
- AWC Active in Modes: Select the modes you want the AWC to “automatically” trigger. Do not select the mode you want to use for MANUAL water changes.
TIP: We recommend using the Normal mode so the AWC triggers during normal day-to-day times.
- Schedule: You can create a simple or complex schedule to run the output.
- AWC Start Time: This is when the controller triggers the first AWC of the schedule. If you only have 1 “Water Change Count,” then this is the time when that AWC starts.
- AWC End Time: This establishes the end of the time range for multiple triggers to activate. If you only have one “Water Change Count,” this field becomes irrelevant. If you have multiple Water Change Counts, the system will divide the starting and ending time range equally by the Water Change Counts’ number.
- AWC Run Every N Days – This feature allows you to start the AWC every X number of days.
TIP: If you want the AWC to run daily, leave this set to One. Two means every other day. Three means every three days. Ten means every ten days. As soon as you slide to select a number, the app will show you the STARTING date of the interval.
- AWC Run on Days of Week: This feature allows you to select which specific days of the week the AWC Schedule should run.
TIP: A Blue circle means the day IS selected.
- AWC Depends On – This feature allows you to turn the SCHEDULE off based on the status of another output. To enable this, select it from the list of available outputs.
TIP: Since your AWC is also your ATO, this option will disable the AWC but leave the ATO part of the output enabled. When OFF, only the AWC part of the output will be disabled. The ATO part of the output will continue to run normally.
- OFF if OFF: Will turn the schedule OFF if the output it depends on is OFF
- OFF if ON: Will turn the schedule OFF when the output it depends on is ON
Step 3: Save your changes
- Tap on the yellow band at the bottom to upload your changes.
