If you are using a battery type other than Lead Acid, you must first disable the charging feature on the Kraken.
Disconnect the battery if connected.
Power down the Kraken by completely disconnecting it from the Mean Well™ power supply. Using a Phillips hand screwdriver, carefully remove the four screws and lid. The lid has three wires connected to the body, so it is best to carefully turn it on its side.
Locate and DISCONNECT jumpers JP3 and JP4 and pull them off. Place them back and ensure the jumper only connects to one pin.
Gently replace the lid and install the four screws, taking care not to overtighten and damage the lid.
Finally, reconnect the Kraken to the power supply.
