HYDROS Online Manual HYDROS Control Add Point Leak Detector
Adding a Point Leak Detector Sensor is very simple.
Step 1: Physically Connect the Sensor
  1. Connect the sensor to your Control unit’s Sense Port (GREEN).
  2. Please safely secure the sensor in your aquarium, making sure that the sensor cannot become dislodged.
  1. From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
  2. Select “Add / Edit Input”
  3. Tap on the + symbol in the bottom-right corner
  4. Enter the name you wish to assign to your input and tap “Create.”
  • Type: Select Sense Port
  • Sense Port: Select the port number where you physically connected the input sensor
  • Sense Mode: Select Point Leak Detector
  • Notification Level: This option lets you specify the notification level you want to receive.
  • Alert When Dry: Select the state that will trigger a notification. If enabled, HYDROS will notify you when the sensor becomes dry.
Step 4: Upload Changes
Once you have configured your INPUT, tap on the yellow bar at the bottom of the screen to upload your changes to the cloud and the individual HYDROS devices.
