Connect the ORP Probe BNC connector to one of the Probe Ports (Light Blue) on the HYDROS device.
Remove the ORP Probe storage container and securely place the probe in your aquarium water.
Step 2: Create the ORP Probe Input
From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
Select “Add / Edit New Input”
Tap on the + symbol in the bottom-right corner
Enter the name you wish to assign to your input and tap “Create.”
Step 3: Configure the ORP Probe Input
Type: Probe Port
Probe Port: Select the port number where you physically connected the ORP probe.
Probe Mode: ORP
Safe Range: This feature allows you to establish a secure range by specifying the minimum and maximum values. If the reading exceeds this range, HYDROS will let you know through notifications, which you can enable.
Graph Value Limits: You can set the minimum and maximum values that appear on the Graphs view.
Offset: You can use this option to make minor corrections. The maximum offset allowed is ±25mV. If the discrepancy exceeds this range, replacing the probe is best.
TIP: If you are using a new probe, it can take up to a week for the probe to settle down. We recommend using the offset option only if the probe is not reading correctly after a full week.
Notification Level: This option allows you to tell the HYDROS what to do when the reading is outside the safe range. You will receive notifications when:
ORP is below the Safe Range Low
ORP is above the Safe Rage High
Control has lost connection to the probe
After configuring the input, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
Type in the new name you wish
