Add Test Schedule
You must establish a Test Regimen schedule for HYDROS to perform Alkalinity tests and update your “Sampled” pH and Salinity inputs.
Step 1: Create the Test Regimen Schedule
- From the main menu, tap on “SCHEDULES.”
- Tap the + symbol at the bottom right and enter your Presets name.
- Tap Create
Step 2: Configure the Schedule
- Type: Select Test Regimen.
- Tester: Select Tester.
- Start Time: Please specify the start time for the day’s first test to HYDROS.
- Run Count (0=No Limit): In 24 hours, how many times would you like HYDROS to perform testing?
- Run Interval: What is your preferred waiting period for HYDROS between the start of each test?
- Active in Modes: Select the modes you want the test to “automatically” trigger.
TIP: We recommend utilizing the Normal mode for this scenario, allowing the testing to occur seamlessly during regular daily usage.
- Run Every N Days: With this feature, you can initiate this testing schedule at intervals of X number of days.
TIP: Keep the setting at “1” to schedule daily testing. For testing every other day, set it to “2”. Similarly, “3” means every three days, and “10” signifies testing every ten days. Once you choose a number, the app will display the starting date of the next testing schedule.
- Run on Days of Week: With this feature, you can choose the specific days of the week when you want the Testing Schedule to run.
TIP: A blue circle indicates an active day.
- Depends On: You can turn the SCHEDULE on/off depending on the status of another output. Select from the list of available outputs to activate this function.
- OFF if OFF: If the output that the schedule depends on is turned off, the schedule will also be turned off.
- OFF if ON: If the output that the schedule depends on is turned on, the schedule will be turned off.
Step 3: Upload the Changes
- Please make sure to upload your changes to the cloud.
