Add Static Input
HYDROS allows you to input manual test readings to monitor your tank’s health. The input values are plotted in a graph.
WARNING: Static Inputs cannot be used to trigger outputs. They are display-purpose only.
Step 1: Create Static Input
- From the app’s STATUS screen, tap on the three horizontal dots to the right of the INPUT label and select “Add / Edit New Input.”
- Type the name of the input and tap on “Create.”
Step 2: Configure your Static Input
- Type: Static Input
- Unit: Select the units of measurement you wish to display in the STATUS screen.
- Safe Range: This feature allows you to establish a secure range by specifying the minimum and maximum values. If the reading exceeds this range, HYDROS will let you know through notifications, which you can enable.
- Graph Value Limits: You can set the minimum and maximum values that appear on the Graphs view.
After configuring the input, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
- From the STATUS screen, tap on the Input you wish to modify.
- From the Input setup page, tap on the “Pencil” icon on the top left.
- If you wish to change the default icon, please tap on “Change Icon.”
