Connect the sensor to your Control unit’s Sense Port (GREEN).
Please safely secure the sensor in your aquarium, making sure that the sensor cannot become dislodged.
From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
Select “Add / Edit Input”
Tap on the + symbol in the bottom-right corner
Enter the name you wish to assign to your input and tap “Create.”
Type: Sense Port
Sense Port: Select the port number where you physically connected the input sensor
Sense Mode: Optical Water Level
Notification Level: This option allows you to specify what notification level you would like to receive. You will receive notifications when
The sensor becomes WET
Control has lost connection to the sensor
Alert When Dry: This option allows you to reverse the status for which you will receive a notification. The Control will notify you if the sensor is dry instead of wet.
Step 4: Upload Changes
Once configuring your INPUT, tap the yellow bar at the bottom of the screen to upload your changes to the cloud and the individual HYDROS devices.
Type in the new name you wish
