HYDROS Online Manual HYDROS Control Add Skimmer Water Level Sensor
Adding a Skimmer Water Level Sensor is very simple.
TIP:
When DRY: This is the normal state and will trigger no action.
When WET: This is the active state. When the sensor becomes wet, it will trigger an action.
Step 1: Physically Connect the Sensor
  1. Connect the sensor to your Control unit’s Sense Port (GREEN).
  2. Please safely secure the sensor in your aquarium, making sure that the sensor cannot become dislodged.
  1. From the STATUS screen, tap the three horizontal dots to the right of the INPUTS label.
  2. Select “Add / Edit Input”
  3. Tap on the + symbol in the bottom-right corner
  4. Enter the name you wish to assign to your input and tap “Create.”
  • Type: Select Sense Port
  • Sense Port: Select the port number where you physically connected the input sensor
  • Sense Mode: Select Skimmer Water Level
  • Notification Level: This option lets you specify the notification level you want to receive. You will receive notifications when:
    • The sensor becomes WET
    • Control has lost connection to the sensor
Step 4: Upload Changes
Once you have configured your INPUT, tap on the yellow bar at the bottom of the screen to upload your changes to the cloud and the individual HYDROS devices.
