Add Constant Output
When you have equipment that requires continuous operation, the Constant Output feature in the HYDROS app becomes a crucial tool. It offers a convenient solution for swiftly adding a device that needs to stay on all the time.
- A HYDROS device or collective with 12V Drive Ports or AC Outlets.
Step 1: Create a Constant Output
- From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add / Edit Output.”
Step 2: Configure your Constant Output
- Family: Constant
- Default to OFF: Here, you can set the default outlet state to ON or OFF. If you enable this option, the outlet will remain OFF until you turn it ON manually or via a dependency.
- Output Device: Here, you select the location of your device you want to turn ON/OFF based on the logic above.
- Active Modes: This allows you to select which mode this output will be operational and which mode should turn OFF.
- Depends On: This feature allows you to turn the output based on the status of another output. To enable this, select it from the list of available outputs.
- Dependency Mode: This allows you to turn the output ON or OFF based on the other output.
- OFF if OFF: Will turn the current output OFF if the output it depends on is OFF
- OFF if ON: Will turn the current output OFF when the output it depends on is ON
- ON if OFF: Will turn the current output ON when the output it depends on is OFF
- ON if ON: Will turn the current output ON when the output it depends on is ON
- After configuring the output, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
