Add Alert Output
An Alarm Output type will trigger when any other output with a matching alarm is activated. To illustrate, setting up a “Red” level Alert output will activate whenever any other output has a Red alert. Moreover, if the alarm produces sound, turning off the Alert output will also silence the audible alarm.
Step 1: Create an Alert Output
  1. From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add / Edit Output.”
  2. Tap on the + symbol at the bottom right of the page
  3. Type in the name of your new output and then tap “Create.”
Step 2: Configure your Alert Output
  • Family: Advanced
  • Type: Alert
  • Alert Level: Here, you can specify which alert level will activate this output.
  • Output Device: If desired, turn on an outlet (WiFi, XP8, or Drive Port) or send a desired 0-10V voltage. Select the output device location here.
  • Power Safe Range: You can set a specific power usage range that is considered “acceptable.” If the power consumption falls outside this range, you will receive a notification if you selected it.
  • Power Notification Level: You can choose the notification level that will activate when power consumption exceeds the “Power Safe Range.”
