Add Light (LED)
Lighting is an integral part of the Aquarium experience, and sometimes, it is required by some of the inhabitants of our aquariums.
- A lighting fixture connected to a HYDROS device with an AC outlet.
- Optional: Temperature Sensor
TIP: You can use the same temperature sensor to monitor the aquarium water temperature. You do not need a separate sensor for the lights. If you have not configured your water sensor input, please follow the instructions
here.
Step 1: Create the Light Output
- From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add / Edit Output.”
- Tap on the “+” symbol at the bottom right of the page
Step 2: Configure your Light Output
- Family: Simple Lights
- Type: Select the type of light you are using.
- Use External Schedule (advanced): You can create a simple or complex schedule to run the lights.
- Used In Schedule: This is a list of all external Light Schedules used by this output. This option will only be displayed if “Use External Schedule” is turned off.
- Start Time: The time at which the light will turn ON.
- End Time: The time light will turn OFF.
- Output Device: Here, you select the location of your Light Fixture. You can select from multiple options such as AC Outlet, Drive Port, or 0-10V Output.
- Overheat Input: Here, you select the Temperature Sensor input.
TIP: To see a list of all inputs available on MULTIPLE devices, you must first
create a Collective. Otherwise, only inputs on the same device will show.
- Overheat Temperature: You select the temperature at which you want the Control to turn your Light Fixture OFF.
- If Input Unavailable: It allows you to specify what the output should do if the input sensor becomes unavailable.
WARNING: If using a WiFi strip or WiFi outlet, this is NOT a “fallback” state. If you are using an XP8 or a Drive Port, it IS the “fallback” state.
- Power Safe Range: You can specify an “acceptable” power use range. If power consumption is outside the range, a notification will trigger if selected.
- Power Notification Level: You can select the notification level that triggers if the power consumption falls outside the “Power Safe Range.”
- Active Modes: This allows you to choose which modes this output will be operational and which modes should turn OFF.
- Depends On: This feature allows you to turn the output based on the status of another output. To enable, select from the list of available outputs.
- Dependency Mode: You can either turn the output ON or OFF based on the other output.
- OFF if OFF: Will turn the current output OFF if the output it depends on is OFF
- OFF if ON: Will turn the current output OFF when the output it depends on is ON
- ON if OFF: Will turn the current output ON when the output it depends on is OFF
- ON if ON: Will turn the current output ON when the output it depends on is ON
- Use Advanced Settings: If you are an expert, this feature will allow you to tweak the output default settings to suit your system better. See Appendix A below for more details.
- Upload your changes to the cloud
Step 4: Create Light Schedule
Now that you have created a Light Output, create a Light Schedule to run the light the way you want it!
Appendix A: Controlled by Light Schedule Settings
- On When Schedule Level Above: This field specifies the intensity in the “Schedule” the output will turn ON.
TIP: Say you set this to 30%. This means that the light will turn on ONLY AFTER the schedule has reached 30% for any schedule that uses this light.
- Overheat Input: Select a temperature sensor to trigger the light to turn OFF if the temperature exceeds your defined max temp.
- Overheat Temperature: Set the maximum temperature before the unit shuts OFF.
- If Input Unavailable: This allows you to specify how the outlet should act if the sensor is not found or missing
- Minimum OFF Time: This allows you to specify what is the minimum time the outlet should be OFF
- Maximum OFF Time: This allows you to specify what is the maximum time the outlet should be OFF
- Minimum ON Time: This allows you to specify what is the minimum time the outlet should be ON
- Maximum ON Time: This allows you to specify what ist the maximum time the outlet should be ON
- Run Past Max ON time: This allows you to specify if you want the outlet to remain ON even if the “Max ON Time” has been exceeded
- Notification Level: This allows you to specify the level of notification you want when any of the advanced settings have been exceeded
TIP: You will get notifications when one or more advanced settings are exceeded. If you set Notification Level to NONE, the particular outlet you configured will not send you notifications.
