Add Protein Skimmer
A Protein Skimmer is an integral part of aquarium filtration.
- Skimmer Pump connected to a WiFi Outlet
- Optional: Water Sensor installed and configured.
TIP: If you have not configured your water sensor input, please follow the instructions
here.
Step 1: Create the Protein Skimmer Output
- From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add / Edit Output.”
Step 2: Configure your Protein Skimmer
- Family: Select “Protein Skimmer”
- Skimmer Level Sensor: Here, you select the Skimmer Level Sensor input. If you created a sensor input, it would be listed here.
TIP: To see a list of all inputs available on MULTIPLE devices, you must first
create a Collective. Otherwise, only inputs on the same device will show.
- Output Device: Here, you select the location of your Skimmer Pump
- Power Safe Range: You can specify an “acceptable” power use range. If power consumption is outside the range, a notification will trigger if selected.
- Power Notification Level: You can select the notification level that triggers if the power consumption falls outside the “Power Safe Range.”
- If Input/Depends On Unavailable: It allows you to specify what the output will do should an input or output it depends on becomes unavailable.
WARNING: If using a WiFi strip or WiFi outlet, this is NOT a “fallback” state. If you are using an XP8 or a Drive Port, it IS the “fallback” state.
- Enable Advanced Settings: If you are an expert, you can customize the default output settings to suit your system better.
- Active Modes: This allows you to choose which modes this output will be active and in which modes the output should turn OFF
- Depends On: This feature allows you to turn the output based on the status of another output. To enable, select from the list of available outputs.
- Dependency Mode: You can turn the output ON or OFF based on the other output.
- OFF if OFF: Will turn the current output OFF if the output it depends on is OFF.
- OFF if ON: Will turn the current output OFF when the output it depends on is ON.
- ON if OFF: Will turn the current output ON when the output it depends on is OFF.
- ON if ON: Will turn the current output ON when the output it depends on is ON.
EXAMPLE: A common dependency is your Return Pump. If your Return Pump turns OFF, the water level in your sump will go up, and it will cause the Protein Skimmer to overflow. In this case, you would set the Protein Skimmer Outlet to depend on the Return Pump. If the Return Pump is OFF, then turn the Protein Skimmer OFF.
- After configuring the output, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
