The HYDROS Control can seamlessly integrate with Focustronic. In contrast to other controllers available, it can directly access Focustronic readings from the cloud, eliminating the need for a cumbersome and outdated pH port connection.
Running a Focustronic machine fully connected to the cloud
Username and password for your Focustronic cloud account (https://alkatronic.focustronic.com)
Step 1: Create a Focustronic 3rd-Party Device
From the app’s STATUS screen, tap on the three horizontal dots to the right of the 3RD PARTY DEVS label and select “Add / Edit 3rd Party Device.”
Tap on the + symbol in the bottom-right corner.
Type the Device’s name. We recommend using “Focustronic” and tapping on “Create.”
Family: Tester
Type: Focustronic Device.
Step 2: Connect HYDROS to the Focustronic Cloud
Model: Select your Focustronic device.
Tap on “Connect” and then tap on “Continue.”
The app will open a browsing page and take you to Focustronic’s Cloud login page. Enter your Focustronic Cloud credentials and tap on “Log in.”
Tap on “Continue” to authorize CoralVue and HYDROS to read your Focustronic readings.
Once you see the confirmation page, return to the HYDROS app and tap “Continue.”
WARNING: WAIT a few seconds for the screen to update!
Step 3: Define the Focustronic Device
Get Focustronic Serial Numbers: Tap on Connect to obtain the list of Focustronic serial numbers. Next, select the serial number of the device you wish to add.
Serial Number: Here, you select the serial number of your Focustronic machine.
After configuring the input, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
Type in the new name you wish
