Add ATO
An Auto Top Off (ATO) system is a must-have if you own a reef tank. This system automatically replenishes evaporated water from your tank. A water sensor is installed in your main tank, and when the water level drops too low, it activates a pump in a freshwater reservoir. This pump then pumps fresh water into your main system.
Step 1: Create the ATO Output
- From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add / Edit Output.”
Step 2: Configure your ATO
- After configuring the Output, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
