Add Chiller/Fan
It’s crucial to maintain the ideal temperature for our coral and fish residents, especially during the summer when the aquarium’s temperature may rise. To prevent this, consider placing a fan near the water surface to increase evaporation and keep the tank cool. However, if the fan isn’t sufficient, you may need to add a chiller.
Step 1: Create the Fan/Chiller Output
- From the STATUS screen on your HYDROS app, top on the three horizontal dots to the right of the OUTPUTS label and select “Add New Output.”
Step 2: Configure your Fan/Chiller
- Family: Temperature Controls
- Type: Chiller
- Turn On At: This option allows you to select the highest point before the Control turns ON your Fan/Chiller.
- Turn Off At: This option allows you to select the lowest point before the Control turns OFF your Fan/Chiller.
- Temperature Input #1 (Required): Select the first temperature sensor input.
TIP: To see a list of all inputs available on MULTIPLE devices, you must first
create a Collective. Otherwise, only inputs on the same device will show.
WARNING: This input is required. If you leave this field blank, the output will automatically go into the “Fallback” state.
- Temperature Input #2: Select the second temperature sensor input.
TIP: HYDROS will use the sensor with the lowest temperature regardless of the input number.
WARNING: If the temperature difference between the two inputs is more than 1C (0.55F), it will trigger an alarm.
- Output Device: Here, you choose the location of your Fan/Chiller
- Power Safe Range: You can set an acceptable range for power usage, and if the consumption goes beyond this range, you can choose to receive a notification.
- Power Notification Level: You can select the notification level that triggers if the power consumption falls outside the “Power Safe Range.”
- If Input/Depends On Unavailable: It allows you to specify what the output will do should an input or output it depends on become unavailable.
WARNING: If using a WiFi strip or WiFi outlet, this is NOT a “fallback” state. If you are using an XP8 or a Drive Port, it IS the “fallback” state.
- Enable Advanced Settings: If you are an expert, you can customize the default output settings to suit your system better.
- Active Modes: This allows you to select which mode this output will be operational in and which mode should be turned off.
- Depends On: This feature allows you to turn the output based on the status of another output. To enable this, select it from the list of available outputs.
- Dependency Mode: You can turn the output ON or OFF based on the other output.
- OFF if OFF: Will turn the current output OFF if the output it depends on is OFF.
- OFF if ON: Will turn the current output OFF when the output it depends on is ON.
- ON if OFF: Will turn the current output ON when the output it depends on is OFF.
- ON if ON: Will turn the current output ON when the output it depends on is ON.
- After configuring the output, tap the yellow bar at the bottom to upload your changes to the cloud and each HYDROS device.
