In some cases, the temperature in the aquarium might go beyond the optimal range for our coral and fish residents, particularly in winter. Therefore, it is advisable to incorporate a heater to aid in maintaining the warmth of the tank.
Heater’s Integrated Thermostat Setup:
HYDROS Controller Heater Output Setup:
In this situation, the HYDROS controller manages the heater daily. It will activate the heater outlet when the tank’s temperature falls below 78 degrees and switch it off when it reaches 78.5 degrees. If the HYDROS temperature sensor malfunctions and the heater remains on, the built-in thermostat will deactivate it once the water temperature hits 80 degrees.
