Add Test Regimen
You must establish a Test Regimen schedule for HYDROS to perform Alkalinity tests and update your “Sampled” pH and Salinity inputs.
Step 1: Create the Test Regimen Schedule
  1. From the main menu, tap on “SCHEDULES.”
  2. Tap the + symbol at the bottom right and enter your Presets name.
  3. Tap Create
Step 2: Configure the Schedule
  • Type: Test Regimen.
  • Tester: Select Tester.
  • Active in Modes: Select the modes you want the test to “automatically” trigger.
    TIP: We recommend utilizing the Normal mode for this scenario, allowing the testing to occur seamlessly during regular daily usage.
  • Schedule: You can create a simple or complex schedule to run the output.
    • Starting Time of Day – It specifies the starting time of the schedule
      EXAMPLE: If you want the output to turn ON at 8 am, STARTING TIME OF DAY = 08:00.  If you want the output to turn ON at midnight, then STARTING TIME OF DAY = 00:00
    • Run Time (How long will the output stay ON) – This specifies HOW LONG a selected output will run
      EXAMPLE: If you want the output to turn ON for 10 minutes every hour, then your RUN TIME = 10 min
    • Run Count (How many times should it repeat?) – This specifies HOW MANY TIMES the “RUN INTERVAL” will consecutively repeat
      EXAMPLE: If you want the outlet to turn ON for 10 minutes every hour, from 8 am to 10 pm, then your RUN COUNT = 14
    • Run Interval (How often do you want the interval to repeat) – This is the sum of the RUN TIME plus the OFF time BEFORE it repeats itself
      EXAMPLE: If you want the output to turn ON for 10 minutes every hour, then your RUN INTERVAL = 60 min
  • Depends On: You can turn the SCHEDULE on/off depending on the status of another output. Select from the list of available outputs to activate this function.
    • OFF if OFF: If the output on which the schedule depends is turned off, the schedule will also be turned off.
    • OFF if ON: If the output on which the schedule depends is turned on, the schedule will be turned off.
Step 3: Upload the Changes
