HYDROS makes it simple to remove a collective device.
Now you can disconnect the old device from your collective. We also recommend resetting the device to ensure a clean removal as an added step. Follow these instructions to reset your HYDROS device.
If you want to transfer the new device to a different email address or a new owner, you must unregister the device and remove it from your account first. Failure to do so will prevent the new owner from registering the device successfully.
Follow these instructions to remove and unregister the device.
