Day Schedule
Here is an example of a “Day Schedule” created by some of our staff members here at CoralVue.
Create a Day Schedule
Create a Schedule and configure it with the following values:
- Type – Set it to “Flow Pattern”
- Pattern – Set it to “Sine Wave.”
- Speed Range – Set the range from 1 to 100%.
- Cycle Duration – 00:01:00.000
- Pump Count – Set this to the desired number of pumps you want to run when this schedule is active.
- Pump # – Select each pump you want to add to the schedule.
- Position # – Select the position you want this pump to assume when running in this schedule.
- Active Modes – Make sure that Normal mode is selected.
- Start Time – 10:00:00
- End Time – 22:00:00
- Run every N Days – Set this to 1
- Run On Days of Week – Select ALL days of the week
- Depends On – Unused
- Enable Advanced Settings – Disabled
