HYDROS Online Manual HYDROS WaveEngine Real Time Notifications
The Control can send you notifications in the event something goes wrong. For example, if, for some reason, the Control becomes disconnected from the cloud, it will notify you automatically.
The HYDROS Control has three levels of notifications:
  • YELLOW – By default, this level will only send you an email
  • ORANGE – By default, this level will send you an email plus a Push Notification
  • RED – By default, this level will send you an email, Push Notification, and sound an alarm
You will get the type of notification specified above based on the notification level you set on the specific INPUT or OUTPUT. For example, placing your Leak Detector INPUT to the RED notification level will get an email, Push Notification, and alarm anytime it is triggered. On the other hand, you will only get an email if you set the notification level to YELLOW.
TIP: Notification preferences are unique to each device/collective. You can set different notification levels for each HYDROS device and Collectives.
What you need to get started
  • A mobile device with the HYDROS app installed
  • Login to your HYDROS account
Enable Notifications
  • Tap on the three horizontal bars in the upper left-hand corner of the Status Screen.
  • Select Options
  • Scroll down to Notification Preferences.
  • Select your notification level. The factory defaults are:
    • YELLOW – Email Only
    • ORANGE – Email + Push Notification
    • RED – Email + Push Notification + Audible Alarm
  • Set your Notification Frequency (how often you will get a notification that an alarm is ON)
WARNING: These settings only apply to the device/collective Owner. They do not apply to Shared Guests. To modify Guest Notification Preferences, please follow this link.
