This screen allows you to view relevant information about your WaveEngine. It allows you to view details for all your Inputs and Outputs.
What is an Input? An Input is a device that sends information to your WaveEngine. Examples of Inputs 0-10V connections such as other controllers, buttons and switches, and 0-10V sensors. All of these types of devices send information to the WaveEngine and it interprets and either will display information for you to see or they can notify you if something isn’t right.
What is an Output? An Output is a place where power or information leaves a system. Examples of Outputs for the WaveEngine would be a flow pump connected to a drive port, a pump or light fixture connected to a 0-10V output channel, or a wireless pump such as EcoTech pumps.
At the top of the screen, you can view running details about your Control unit, such as:
Below the Control details, you will find the Modes Section to see all available modes. To the right of the MODES label, you can see the name of the active mode.
You can activate a mode using two different methods:
Here you have a list of all available inputs (0-10V Inputs). To change the view on the inputs, tap on the three horizontal dots to the right of the INPUTS label, and select from:
If the input is blue, then the readings are within acceptable range. If the input is red, then the readings are outside the acceptable range, or the Control cannot get a reading. In this case, if enabled, a notification will be sent to you.
You can edit an input by tapping on the square tile, name, or graph.
Here you have a list of all available outputs. To change the view, tap on the three horizontal dots to the right of the OUTPUTS label and select from:
If the output is blue, then the output is “auto” ON. If the input is GRAY, then the output is “auto” OFF. If the output is yellow, then the output is MANUALLY overwritten ON or OFF. If the output is RED, then there is an issue with the outlet. In this case, if enabled, a notification will be sent to you.
