Protected Enclosure
HYDROS Ports
Controls
WaveEngine
Setup
FAQ
Contact Us
View Example Setups
Products
Controls
Maven Water Tester
View More
Launch
View More
Minnow
View More
Control X4
View More
Control XP8
View More
Control X2
View More
Control X10
View More
Kraken
View More
All Controllers
View More
Sense Port Accessories
Magnet Mount Temp Sensor
View More
Triple Optical Water Level Sensor
View More
Dual Inline TDS Sensor
View More
Water Level Sensor
View More
Skimmer Sensor
View More
Point Leak Sensor
View More
Rope Leak Sensor Kit
View More
Float Switch Sensor
View More
Flow Sensor
View More
Slim Temperature Sensor
View More
Drive Port Accessories
Auto-Top-Off Kit
View More
HYDROS iV
View More
DC Micro Pump
View More
CO2 Solenoid Valve
View More
Simple Dosing Pump
View More
Solenoid Water Valve
View More
WiFi Accessories
WiFi Power Strip
View More
WiFi Fish Feeder
View More
WiFi Smart Plug
View More
Other
HYDROS 2mL-min Dosing Pump
Cables and Adapters
Sense Port Extension Cable
Drive Port Extension Cable
Drive Port Cable
0-10V Quad Cable
Command Bus Cable (DATA Only)
Command Bus Cable (DATA+Power)
HYDROS Command Bus Terminator
HYDROS Kraken Battery Backup Cable
HYDROS Kraken Force Port 24v Adapter Cable
HYDROS Kraken Force Port Power Cable
WaveEngines
WaveEngine
View More
WaveEngine LE
View More
Setup
Web App
Community
Where to Buy
HYDROS Online Manual
HYDROS WaveEngine
Rename a WiFi Device (WaveEngine v2)
To rename a WiFi Outlet Strip:
From the Status screen, tap on the WiFi Strip you wish to rename
To the left of the name at the top, tap on the pencil icon
Type the new name of your WiFi Strip and tap on “Rename”
Upload your changes
Print This Page
Setup the HYDROS App
Download the HYDROS App
Creating a Cloud Account
Connecting to Your WiFi Network (Bluetooth)
Updating to The Latest Firmware
Real Time Notifications
The Rest of The App
Understanding the Status Screen
Understanding the Options Screen
Overriding Individual Pumps
Sharing HYDROS Devices/Collective Access
Account Preferences
Device Properties
Backup & Restore
Pair WiFi Devices
Pair WiFi Strip/Smart Outlet (WaveEngine v2)
Pair WiFi Feeder Device (WaveEngine v2)
Add Inputs
Add 0-10V Input
Add Outputs/Flow Pumps
Add A Flow Pump (Direct Drive)
Add A Flow Pump (0-10V)
EcoTech Marine VorTech™ Pumps
Schedules
Add Flow Pump Schedule
Modes
Create a Mode
Pages
Add a Page
Schedule Examples
Feeding Schedule
Hurricane Schedule
Day Schedule
Night Schedule
Mode Examples
Feeding Mode
Water Change Mode
Low Power Mode
The Collective
HYDROS Collective 101
Add WaveEngine to Collective
Removing a Collective Device
3rd Party Controllers
Activate Feeding Mode
Activate Water Change Mode
Troubleshooting
Breathing Yellow
Breathing Red
“Pump Locked, Stuck in Closed Loop” Error
“Cloud Registration Failed = Conflict” Error
Read-Only Mode
Configuration Stale Warning
Unregister a Device
Rename a Device
Reset to Factory Default
Update WiFi Credentials
Bad SD Card
