Water Change Mode
A water change often requires all flow pumps to be turned off. Since a Mode without triggers assigned to it will cause the pumps to turn OFF completely, all we need to do is create an “empty” mode.
A Water Change mode comes preconfigured with your WaveEngine but if you need to recreate it, here is how to do it:
Step 1: Create Water Change Mode
- Go to the Main Menu and select MODES.
- Tap on the + symbol on the bottom right and create a new mode called “Water Change.”
Step 2: Configure Water Change Mode
Don’t forget to save your changes!
Step 3: Activate Water Change Mode
- Go to the Status Screen and tap on the Mode at the top. You will be able to select Water Change Mode from the list.
