HYDROS Online Manual HYDROS WaveEngine Configuration Stale Warning
Suppose on your HYDROS app you receive a “Configuration Stale” warning. In that case, it simply means a different mobile device or computer recently updated the configuration, and the local configuration on the current device is outdated.
To fix the problem, tap on the red bar, and the app will automatically download the most recent configuration to the local device.
This feature prevents a device with an old configuration from overwriting a newer configuration and erasing all recent changes.
WARNING: Any changes you make while the “Configuration Stale” red bar is displaying will be lost when your device downloads the newer configuration from the cloud.
If you wish to override the newer configuration with the older version (strongly not recommended), make your way to the Status screen, tap the three dots on the upper right-hand corner and select “Upload Changes.”
