Reset WiFi Configuration
In some cases, if during setup, you entered the incorrect WiFi credentials or, if you changed your WiFi settings, you may need to reset the WaveEngine’s WiFi settings back to the factory default.
Resetting the WaveEngine’s WiFi Settings
- Place a small magnet on top of the letter A on the word WaveEngine.
- The WaveEngine will flash:
- Rainbow, then
- Green, then
- REMOVE THE MAGNET as soon as you see yellow LEDs going around clockwise.
- The WaveEngine will reboot and then will breathe BLUE.
- Connect your WaveEngine to WiFi.
