Reset to Factory Default
Sometimes, you may need to reset your IceCap Dual Controller (ICDPC) back to factory settings.
Step 1: Power the Unit
Make sure the unit has power. Confirm that the green LED on the power supply is ON.
Step 2: PURPLE Reset:
- Insert a paper clip on the side pinhole and hold the paper clip against the button.
- The controller should turn the lights ON, and it will show rainbow colors followed by chasing green, then chasing yellow, then chasing red, and then chasing PURPLE
- When you see chasing PURPLE, remove the paper clip, and allow the controller to restart.
Step 3: YELLOW Reset:
- The controller should turn the lights ON, and it will show rainbow colors followed by chasing green, then chasing YELLOW
- When you see chasing YELLOW, remove the paper clip, and allow the controller to restart.
The controller is now back to factory settings.
If you wish to reconfigure the controller, rerun the setup.
