During feeding mode, the HYDROS will automatically stop all pumps (Direct Connect and 0-10v), allowing tank inhabitants to eat.
In some circumstances, the hobbyists may prefer to slow down the flow pumps to minimum speed instead of turning them OFF and allow the slow-eating inhabitant to feed.
TIP: If you want to run the pumps at minimum speed during feeding, refer to the Feeding Schedule on the Schedule Examples section of the left navigation.
Activate Feeding Mode Using 0-10V
From the Main Menu, select MODES and then tap on FEEDING.
- INPUT VOLTAGE – Set the voltage number to match the one coming from your 3rd party controller.
- MODE TIMEOUT – This field is ignored if you activate the mode via MODE CONTROL INPUT and 0-10v connection.
- EXIT DELAY – Set this to 0.
- LED COLOR – Set it to your personal preference.
From the Main Menu, select OPTIONS.
- MODE CONTROL INPUT – Set this to match the 0-10V IN channel you are using to trigger the Mode change.
- Go to the Status Screen and tap on the “Feeding Mode” button to activate. If you are using 0-10V, just set the other controller to send the same voltage you specified on “INPUT VOLTAGE.”
