Activate Feeding Mode from HYDROS Control
Sometimes, one may want to allow the IceCap Dual Pump Controller (ICDPC) to control the flow pumps in our tank, but at the same time, have your HYDROS Controller activate the feed mode on all connected devices.
It brings the best of both worlds into one. Allow the ICDPC to do what it does best while triggering modes such as Feeding or Water Change with a SINGLE button click.
- HYDROS Control X4, HYDROS WaveEngine, or HYDROS WaveEngine LE controller with an available 0-10V port (Ethernet) and the latest firmware installed
- HYDROS 0-10V Quad Cable
Step 1: Connecting the HYDROS 0-10V Quad Cable
- Connect the single end of the HYDROS 0-10V Quad Cable (GX12) to the HYDROS Control 0-10V OUT port.
- Connect one of the four 3.5mm ends of the HYDROS 0-10V Quad Cable to the side of the IceCap Controller. Be sure to remember the color of the cable end.
TIP: The 0-10v cable has four different connectors.
- BLACK = Direct Output 1
- BROWN = Direct Output 2
- RED = Direct Output 3
- ORANGE = Direct Output 4
Step 2: Configure your HYDROS Control
Step 3: Save your configuration
- Tap the yellow bottom band to upload your changes to the cloud and your HYDROS Control.
Step 4: Configure the ICDPC
TIP: Select an LED COLOR in the mode configuration screen, and the ICDPC will display it while the Feeding Mode is active!
Step 4: Save your configuration
- Tap the yellow bottom band to upload your changes to the cloud and the ICDPC.
Now you can activate your Feeding Mode on your HYDROS Control. First, it will send a 5-volt signal to the ICDPC. Then, after matching the voltage to the Feeding Mode, the ICDPC will activate it.
