An aquarium controller capable of controlling and monitoring aquarium equipment and measuring pH/ORP levels.
HYDROS Control X3 can connect to two sensor devices, including temperature sensors, water level sensors, and leak detectors. The device also includes a Probe Port for monitoring pH and ORP levels. This compact controller is ideal for both saltwater and freshwater aquariums and can be used on its own or with other HYDROS Control devices. Control X3 can send alerts and notifications and control outlets for lights, pumps, feeders, and more. Learn more about its features and industrial design below:
Probes are only as good as their signal. The Control X3 ensures your readings will be accurate and reliable.
The HYDROS App allows you to create rules and set schedules to control our 4-Outlet WiFi AC Power Strips and Smart Outlets. Quickly turn on or off different pieces of aquarium equipment like pumps, powerheads, lights, heaters, algae scrubbers, UV sterilizers, protein skimmers, and more.
The Command bus not only powers the Control, but it also communicates with other HYDROS devices for the ultimate failsafe.
The Control X3 Starter Pack retails for $299.99 and includes all the essential equipment needed to control and monitor an aquarium.
There is no complicated programming language to learn. If you can operate a smartphone, you can be the operator of a smart aquarium—tap, drag, press, or flick to adjust settings using intuitive icons and simple menus. Schedule each component in your aquarium life support system to run at a specific time, frequency, or intensity. You can also use real-time data and easily configure more complex actions.
HYDROS brings a new standard to the aquarium industry with a controller that is resistant to the elements. Industrial grade materials help the controller’s enclosures stay rugged and secure, even when it comes in contact with moisture or saltwater!
Leaving a cord unplugged or forgetting to turn a device back on can have devastating consequences on your aquarium. With the HYDROS App’s notification alerts, you can protect your investment and turn a possible disaster into nothing more than a simple inconvenience.
Control your aquarium gear locally through WiFi, which you do not need an internet connection for, or remotely using the HYDROS Cloud. The HYDROS Cloud allows you to securely and reliably communicate with the Controls through the internet.
For those who prefer a direct connection, the Control XP8 is a great option that includes eight individually controlled outlets offering the highest level of security. Like the other WiFi outlets, the Control XP8 can also control up to eight HYDROS WiFi devices.
*HYDROS WiFi Power Strip and Smart Outlet requires HYDROS App and a Control unit to operate. Control XP8 is a HYDROS controller and only requires the HYDROS app.
We strive to provide an experience that allows the HYDROS community to easily engage with us, each other, and other aquatic enthusiasts every day.
We love hearing from you! Keep the feedback coming.
