HYDROS Two-Part Dosing Setup
For Maintaining Stable Water Chemistry
The Minnow aquarium controller is a device that helps to maintain stable water chemistry in reef aquariums. It is equipped with two independent micro-liquid dosing pumps, four Sense ports, and a Command Bus. With additional accessories, it can detect leaks, monitor water levels, and control up to eight WiFi devices, among other things. The Minnow is synced with the HYDROS App, which allows for convenient aquarium management. You can combine the Minnow with additional controllers to establish a completely automated two-part dosing regimen, ensuring a safe and comfortable environment for aquatic pets.
Aquarium Details
Size: 200 U.S. Gallons
Type: Saltwater Reef
Age: 3 Year
Fish: Reef Fish
Equipment Used
Minnow, Control X4, XP8, Water Level Sensors, Temperature Sensor, Rope Leak Detector, HYDROS Launch, pH Probe, Micro DC Pump, Skimmer Sensor
The HYDROS App Interface
Basic HYDROS Setup
This setup has 3 controllers and 6 Sense ports for water level, skimmer, and temperature sensors. It also has 1 Drive port for the HYDROS DC Micro Pump, and 1 Probe port for pH measurement. All outlets can power and control other aquarium devices like heaters, skimmers, return pumps, and lights.
The HYDROS App is intuitive and allows you to create personalized rules and schedules. You can control various outputs or devices based on inputs such as leak detectors or water level sensors. For example, if the water level sensor detects low liquid, the dosing pump will be disabled, and you will be alerted.
Are you ready…
to take full CONTROL of your aquarium?
The HYDROS product line offers several different controllers. Each controller caters to the different needs of an aquarium, making it incredibly easy to find the right unique setup for your tank. The best part, the Controls can adapt to your changing or growing aquarium. Unlike other popular controllers, the Control device you purchase today will work with any HYDROS products available in the future. All of the Controls have the ability to work together – allowing you to manage all of your aquarium’s devices from one single interface on the HYDROS App. This feature is called the Collective and it is what sets the HYDROS Controls apart from other controllers on the market.
We would love to help. Fill out the form and a CoralVue HYDROS representative will be in contact with you soon.
