Size: 150 U.S. Gallons
Type: Reef Tank
Age: 3 Years
Fish: Assortment of Saltwater Fish
Temperature Sensor, Water Level Sensor, Skimmer Sensor, pH Probe, Rope Leak Detector, ATO Kit, Lights, Heaters, Sump, Skimmer, Return Pump, Flow Pumps, Algae Scrubber, Automated Water Testing Device, Dosing Pump, WaveEngine LE, Control X4, Control XP8, WiFi Smart Plug
This setup includes 10 inputs for the temperature sensor, water level sensors, pH probe, rope leak detector, and a variety of elements tested by the automated water testing device. There will also be 11 outputs for the scrubber, testing device, heaters, lights, pumps, etc., and one (1) WiFi device for the smart outlet.
With the user-friendly HYDROS app, you can create rules and set schedules to command outputs to be On or Off. For example, if the temperature sensor reads that the aquarium is too hot, you can create a rule that will turn off the output your heater is plugged into. That will prevent it from going past a safe level and alerting that there is an issue.
The HYDROS product line offers several different controllers. Each controller caters to the different needs of an aquarium, making it incredibly easy to find the right unique setup for your tank. The best part, the Controls can adapt to your changing or growing aquarium. Unlike other popular controllers, the Control device you purchase today will work with any HYDROS products available in the future. All of the Controls have the ability to work together – allowing you to manage all of your aquarium’s devices from one single interface on the HYDROS App. This feature is called the Collective and it is what sets the HYDROS Controls apart from other controllers on the market.
We would love to help. Fill out the form and a CoralVue HYDROS representative will be in contact with you soon.
